topherharris
#1 Posted : Saturday, August 24, 2019 7:47:58 AM(UTC)
topherharris
I'm going to do a simple multi vMix Call setup with four participants. They want all participants to appear on screen at the same time with no cutting to individual shots. There will be one video to roll in.
I know their audio will be mix-minused automagically by vMix, but can their video be minused? (I'd like them to not see themselves.)
I figure I can send them a different output, but I'm limited to three outputs, no? (I see Outputs 1-4 and None, but #1 is Program)
So, if there was Mix-minus for Video, I could just send them Program.
If there were more Outputs, I could send them each their own feed, minus themselves, with the fourth box containing the roll-in.
Any better way of doing this?
-topher
mashynewie2
#2 Posted : Sunday, September 8, 2019 6:05:44 PM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
There is no mix minus for video.
You can achieve this by creating 4 custom "inputs" which show all participants except for themselves then feed that input back to each caller.
So yes, it can be done if you set it up manually.
thanks 1 user thanked mashynewie2 for this useful post.
mjgraves on 9/11/2019(UTC)
