Data Sources Update Quicker
Joined: 5/30/2019(UTC) Posts: 1  Location: Mobile, AL
We are using the Data Source feature within VMix to update a team stats graphic using Google Sheets. The graphic has about 20 fields that are updated during a game. Sometimes VMix updates the graphic very quickly other times it takes up to 90 seconds. We are broadcasting live and 90 seconds is a very long time to wait on a graphic to update. Is there a way to make this process quicker? The computer used to update google sheets is on the same network as VMix.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
google api allows ony updates ,i think, every 8 seconds. i was putting in 9 seconds in the data source update time field. a value below caused api errors.
