Often when trying to use a http request or use a function in a script it's practical/handy to check in the add shortcuts on what is needed (as a reference).
would it be possible to have a bit more consistency in the various options needed/used please
as a recent example in this forum for example:
changing an image in a title with a shortcut function : - Function: SetImage - Input: the title name - Image: the placeholders name - Value: reference to the image
but in a http request or in a script one has to use SelectedName or SelectedIndex instead of Image while all the others are the same as for a shortcut.
is easy to forget the difference and gets frustrating why a function isnt working as planned If at least the other naming options were mentioned in the Add Shortcut Gui's like a little helpline that would be a big help.
Tnx for considering
