IanM
#1 Posted : Sunday, August 11, 2019 6:23:00 PM(UTC)
IanM
When I have a list of rows within a spreadsheet, shown in Data Manager, I can click on the list to select a graphic.
If I sort the list, by clicking in the column header, the list is sorted in order of that column. However, the sorted list doesn’t refer to the same items as before. This makes it impossible to use It would be better to disable the feature to avoid accidental clicks.
Also, one of my columns contains the row number, so I thought that I might get out of my situation by sorting on that column . Unfortunately, the sort is an alphabetic sort, so I ended up with 1,10,11,12,13,2... etc
The problem is solved by updating the source excel sheet, which will reload the data, but this is not ideal.
dasmedienatelier
#2 Posted : Sunday, March 21, 2021 11:28:08 PM(UTC)
dasmedienatelier
+1
