Haitham
#1 Posted : Friday, August 9, 2019 3:37:24 PM(UTC)
Haitham
Hello all
am working on a project and i got stuck trying to control virtual set zoom speed from API,, i can change the index from the API, but i cant find a way to change the speed from the API ,
here is my current scenario
VCAM1 is a Virtual set
index 1 is at zoom 2
index 2 is at zoom 1
speed it 35 seconds
am changing the index to 1 from the API , before the end of the zoom am cutting to another CAM,
now i want to start the VCAM1 from Top
so i want to set the duration to 0 change index to 2 , set back the duration to 35 seconds , change index to 1, cut to VCAM1 .
but i cant figure out how to change the duration for the zoom in virtual set.
Can anyone help please ?
Regards
Haitham
