lbgaus
#1 Posted : Friday, March 21, 2014 11:03:03 PM(UTC)
lbgaus
Hi Martin,
Have you observed any issues putting MPEG-2 TS sources recorded in vMix back in as an Input after the recording is completed? It appears no audio is played back, even though it is present in the recording if played back in a different player.
Thank you.
Charssay
#2 Posted : Saturday, March 22, 2014 4:16:15 AM(UTC)
Charssay
Hello Ibgaus
I notice this also this issue long time ago. My solution was simple. As I did install several codec on my Computer, I choose in Decoders Setting another one that the Microsoft-DVD decoder. actually i use the Nvidia Decoder for that
I did Notice it also when I was playing DVD Video
If you have Cyberlink DVD 9 or higher already installed on your Computer, try to choose it as Audio Decoder in the Setting and See what happen.
C.
lbgaus
#3 Posted : Wednesday, March 26, 2014 1:50:33 AM(UTC)
lbgaus
Hi Charssay,
Thank you for contributing your idea. Unfortunately, I have not purchased the Cyberlink software, I might try to get my hands on it to attempt it, but I think it might be something for the Haali splitter or whatever is set to demux that video as it enters vMix, but I do not know much about how this works at the moment.
Any thoughts without changing decoders? Thanks!
#4 Posted : Wednesday, March 26, 2014 4:51:33 AM(UTC)
Please try the latest update here:
http://www.vmix.com.au/download.aspx
12.0.0.120 should play back MPEG-2 TS with audio as long as the latest AC3Filter is installed.
The AC3Filter web site is currently not working but I found a recent download here:
http://www.free-codecs.com/ac3_filter_download.htm
lbgaus on 3/26/2014(UTC)
lbgaus
#5 Posted : Wednesday, March 26, 2014 11:03:20 AM(UTC)
lbgaus
Thank you Martin, this is working correctly now.
