crimonist
#1 Posted : Wednesday, August 7, 2019 3:51:50 AM(UTC)
crimonist
It would be great to have the ability to quickly change, via shortcut, the trigger package on a particular input.
When we're using replay, there are certain times during the broadcast where we would like to be able to change the mix of triggers in use when going in and out of replay. Of course this can be done manually, but it would be superb if there were a way to toggle between different presets (and have corresponding shortcuts to select the desired preset).
