Had some troubles yesterday starting vMix v21
then upgraded to 22, registration file corrupted, program hung all day at logo screen, multiple attempts to start.
Finally in the evening it powered up like nothing happened.
Except, open file v21 file in v22 and all shortcuts and keyboard shortcuts are gone, table is empty, I did not save the opened file.
Downloaded V21 and installed in new location, same result, opened file previous file, all shortcuts gone.
Where are the shortcuts stored? any way to get them back? Lot of work went into those and the logic...
(they were not saved as "local to this preset")
thanks
There is a way to Export ShortCuts for backup or use on another vMix system. The file is saved as *.config.
Do a search on your computer to see if such a file exists.
