Datasource Title Template Set Source API
Hi All,
I have been doing some searching and cannot find a way to do this. I have a JSON file supplied to me that separates out heats for a track and field event. Here is my issue each heat has its' own row and in each row, there is a list of runners in the heat. This is easy to work with when showing the whole list of a given heat, but I want to make a lower third for each competitor, currently, I need to make a separate input in vMix for each "Column" or "runner name/info". I would like to use scripting to set a different column for a given title template.
Thanks for your help in advance.
