shinyidol
#1 Posted : Thursday, July 18, 2019 8:47:07 AM(UTC)
shinyidol
Since vMix is using the GH5 in their shows, I'm curious how they handle the delay? we are seeing about a 1-second delay with our Yuan capture card with loop to a monitor.
ukcpw
#2 Posted : Friday, September 27, 2019 11:25:22 PM(UTC)
ukcpw
Hi shinyidol
The GH5 HDMI output already has a 140ms delay. So depending on which frame rate your session is, you will have a couple of frames with the capture card, then vMix, then the output card... which will lead you to at least 300ms.
We use GH5s sometimes with vMix, and you could have between .5 and a second delay in a screen if you use multiviews and other stuff...
