Tip: cheap usb webcam for (church) broadcasting
Rank:: Advanced Member
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I was looking for a cheap way to add some atmosphere images to our church broadcastings. I bought a couple of xbox360 live vision webcams on ebay ($10,= each). This camera has a very good quality and is supported by vMix (add capture device). The image delay is hardly noticeable. The usb cable is 3m, but with a usb (cat5) extender you can put this camera's anywhere. There are plenty sites on the internet with information how to replace the M12 lens.
Joined: 1/29/2014(UTC) Posts: 24  Location: Las Angeles, CA Was thanked: 3 time(s) in 3 post(s)
The Logitech c920 is the best webcam and is only 69.99 right now.
SKYGIF wrote:The Logitech c920 is the best webcam and is only 69.99 right now. Thats a great webcam, but it overshoot the target a little bit. It's not cheap if you want to use a lot of them and it's HD, so you have to crop to 4:3 if your other (PTZ) camera's are not HD. Mixing between 4:3 and 16:9 camera's in a broadcasting is not pretty. The c920 is also 2 times bigger, so less discrete to mount in e.g. a church. The Xbox vision cam has also manual focus, so you can focus at what ever you like for special atmospheric images.
