Please add a crop function to the stream signal. It is avaible on the Flash Media Live Encoder, so it should be in vMix as well. Thanks !
By the way, also please check the console where Adobe Flash Media dos software is starting. On the first screen i've see a timecode error in vMix. Is it okay? It is visible so tiny amount of time, that it is hard to read ;)
