Need to hire some VMix Help!
Hi All, I'm a n00b here, but wanted to reach out on a project I'm on that I don't have the time to learn VMix from scratch and setup a test to determine if this will work for our intended application. To that end, I'm looking to hire someone for a couple of days to help setup and test something like the following. 1. VMix - setup on a remote test PC, via LogMeIn access to make sure firewall and connections are properly set 2. Setup 10 virtual inputs - ALL of these would be RTMP or RTSP streams - we don't care where the test streams originate from as long as they are A) not porn, and B) preferable if they are 720p, better if 1080 - all from IP cams 3. Demonstrate live switching to a Ustream endpoint. We're investigating using VMIX to source/preview 10 cameras like these: http://www.axis.com/products/cam_q6045c/index.htm, 24x7 for 6 weeks in a very remote part of the world - assuming I can get internet service there. I can pay for the help, our total budget would be $500USD to setup and successfully test this - payable with 1/2 upfront, 1/2 on completion of test; and we would likely start putting this together on Monday, March 10th. Many thanks, Jon
Joined: 6/29/2011(UTC) Posts: 315   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
MPGjon, Give these guys a call, They're doing what your talking about. Mike Connell 321-888-3800 www.sportzcast.net
