sam
#1 Posted : Thursday, February 27, 2014 12:46:58 AM(UTC)
sam
Hi
This is Sam using vmix HD Pro version in Korea
I'm planning to live stream some conferences next month using 24:9 ratio ouput for PIP (PPT & Real time event)
I couldn't find this feature in vmix (lasted ver.), so i'm requesting it for good later.
thanks,
Sam
radamo
#2 Posted : Friday, February 28, 2014 9:29:31 AM(UTC)
radamo
That is a great idea !
vmix could be used for live event on big screens with several projectors with softedges
Olivier
homeless
#3 Posted : Saturday, May 24, 2014 10:47:02 AM(UTC)
homeless
Groups: Guests
And may be interest create options for videowalls output ? - output "device" can consist from 2-3-4-.... monitors (included in Windows as extensions of desktop, оr in vMix may be pssible create virtual videowall from all monitors connected to PC)
richardgatarski
#4 Posted : Tuesday, May 27, 2014 6:40:36 AM(UTC)
richardgatarski
I'm not sure how this would work in practice, unless your sources has that resolution.
Maybe this workaround could help in the short runt.
Set resolution to 1920x1080, only put content in a sort of letterboxed 1920x720 area (using vMix's positioning features), and then crop the top/bottom parts with the projector (or some kind of scaler, should exist by I don't know any). Or upgrade to 4K if you need higer vres than 720.
