jan211984
#1 Posted : Saturday, August 27, 2011 12:45:59 PM(UTC)
jan211984
Hi all!
my set up:
i5-2400
16g ram
ASRock Z68-Pro3
1*Blackmagic Design Intensity Pro HDMI input (with Canon HV30 HDV)
1*Logitech C910 webcam
FMLE 3.2 (set video in 24p)
I set vMix Virtual Capture in 23.976p in External setting,
and trying to stream with FMLE. but when I stream to Justin.tv or Ustream,
my Frame Rate shows in FMLE is 30(when switch to HDV input in vMix) or
25(when switch to C910 webcam), not 24 nor 23.976.
and Bit Rate is much higher then my setting.
I set it as 2100 Kbps, but always around 3000 when I switch to HDV.
Is this a bug? can I fix it?
and thank you Martin, vMix is so great, resources cost is much lower than other applications I've tried before.
-Noah
#2 Posted : Sunday, August 28, 2011 2:57:25 AM(UTC)
Hi Noah,
By default vMix will output at whatever frame rate the source is running at.
If you would like to limit the frame rate of a particular source:
1. Set "System" under the Settings -> Display tab to the frame rate you would like.
2. For each input, click the i button and untick the "Self Render" option under the Advanced tab.
Hope that helps.
flvlef on 11/25/2014(UTC)
flvlef
#3 Posted : Tuesday, November 25, 2014 1:53:54 PM(UTC)
flvlef
Regarding the "custom output framerate".
I think VMix had some changes since August 2011 :)
So in the 14.x version can we :
1. set a particular framerate to the external output ? (i.e. : 18fps)
2. stream via FMLE API using a particular framerate
For the moment I'm just able to use the framerate listed (i.e.: 25p, 30p etc.)
Thank you very much.
flvlef
