adbjlb1
#1 Posted : Tuesday, May 21, 2019 1:28:53 AM(UTC)
adbjlb1
I am attempting to use the countdown title to trigger the start of show. I am attempting to use a specific time of 7:00 PM: using the XAML
{0:07:00 PM|mm:ss}
When I set the trigger to transition on countdown complete it does not transition when it hits 0 I tried to set the timer to move form the overlay on completion and attempt to set the transition off of that but still when the countdown reaches 0 the overlay does not move and nothing is triggered. Can Anyone help?
#2 Posted : Tuesday, May 21, 2019 12:06:25 PM(UTC)
@ adbjlb1
I think that technically this is not a considered countdown by vMix because you are using the Time of Day from the PC's clock, which doesn't stop or have an end time.
You need to use an actual "stop watch" or countdown timer which is not regulated by the actual Time-of-day.
