Eyes.Only
#1 Posted : Wednesday, May 15, 2019 2:58:06 PM(UTC)
Eyes.Only
Is there a means to add just audio from another pc on the network (similar to if I used vMix desktop capture, but I don't need video... just audio). Unless vMix DC does have an audio only option?
sinc747
#2 Posted : Wednesday, May 15, 2019 3:28:23 PM(UTC)
sinc747
Was thanked: 205 time(s) in 171 post(s)
What's the source of the audio on the 2nd PC? MP3? Separate audio mixer? Webpage?
I'm guessing vMix Desktop Capture (using NDI behind the scenes) will be you best choice.
- Tom
