MeanTime69
#1 Posted : Tuesday, May 14, 2019 11:40:56 PM(UTC)
MeanTime69
I just got two P4000 cards and was tinking about SLI using vmix, I have read that i need to use a quadro sync II card as well. Which would be better, SLI or sync II for vmix?
Thanks,
MeanTime
mjgraves
#2 Posted : Wednesday, May 15, 2019 1:16:28 AM(UTC)
mjgraves
vMix does not accommodate SLI. They specifically recommend against it.
JoseL
#3 Posted : Friday, May 17, 2019 5:45:51 PM(UTC)
JoseL
Was thanked: 19 time(s) in 13 post(s)
Are different... sync II is for sync both card outputs perfectly. With sli you loose output of one of the cards
You will not get any improvement on vmix with sli, but maybe other applications can improve. On games improvement is near double.
Nvidia nvenc is same with one or two cards on vmix.
Actually is better to buy 1x p5000 than 2x p4000 for vmix.
Regards
Thanks,
MeanTime
