spino
#1 Posted : Tuesday, May 7, 2019 4:19:27 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
When we use a chromakey, sometime it's needed just a crop of a little piece of corner but using X or Y, a large part of the shot is cut. I think that it could be a good idea the possibility to have four more axys (Z1up, Z1below, Z2up and Z2below) rotated to 45 degrees (or with the possibility to rotate them as we need), to crop just a little part of the shot. This could be useful at most when, for example, it's used a rounded background like a collassible green screen that is rounded at the corners.
Gunnar
#2 Posted : Friday, May 17, 2019 7:52:32 PM(UTC)
Gunnar
Sweden
+1 for this. Would be making it much easier in many situations with chromakeying.
richardgatarski
#3 Posted : Friday, May 17, 2019 9:09:33 PM(UTC)
richardgatarski
I think it is generally better to fix that with luma keying (before the chroma keying), ie create a mask and adjust its size and position.
