Feature Requests
Image update option in web title editor
Joined: 8/26/2017(UTC) Posts: 11  Location: UK Was thanked: 4 time(s) in 3 post(s)
Is it possible to add the image update option in the web title editor. Would be great to be able to point to a new image file as well as update the txt from the web interface.
Jon
Joined: 4/11/2015(UTC) Posts: 64   Location: Home Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
SetImage is the api command your looking for...
SetImage
Change Image in Title according to Filename or empty to clear.
SelectedIndex or SelectedValue can be used to select text field.
Value = Filename
Value,Input
https://www.vmix.com/help19/index.htm?DeveloperAPI.html
about 1/3 of the way down...
Feature Requests
