skoota
#1 Posted : Saturday, April 20, 2019 8:50:19 PM(UTC)
skoota
Hi All,
Newbie to vMix here. I am looking at moving to an "At Home" broadcast setup, where cameras in the field transmit their vision over 4G/LTE which is then mixed/switched at a home studio location. I have been reading quite a few forum posts about people using the Teradek Bond with the Teradek Core service (Sputnik server) and then TCP Pulling that into vMix. Before going any further, I am curious about what delay/latency we could expect end-to-end? I know this depends on a lot of factors, particularly the internet situation, so let's assume that the cameras in the field are running 4x USB LTE modems with very good coverage/speed, and the home studio has gigabit fibre.
The reason for asking is that in some cases we need to push the mixed program feed back out to the field location for display on an LED screen / Jumbotron - so I am trying to assess how much delay would be introduced (and whether the feed being returned would be a jarring experience at the venue if it is too delayed).
Thanks!
dark_ata
#2 Posted : Sunday, April 21, 2019 4:15:02 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
we have old teradek bond pro and II, and really the delay using bond>sputnik>vmix is high, we usually uses 3seg in the bond, and normally is arround 5.5-7 seg in vmix, using liveu or dejero and sdi we get very low delay. the lowest that we have is arround 3s, using 1s in bond.
also you need add the cost of core services, we have a base server and a cloud with old version of the sputnik and not pay for traffic or 75$ per sputnik cloud.
