wscawebcast
#1 Posted : Wednesday, February 5, 2014 7:24:19 PM(UTC)
wscawebcast
I've got:
- 5 inputs ("Scoreboard 1-5") based on a single IP camera, each cropped to show a different portion of the image being streamed
- 10 inputs ("Cameras 1-10") based on 10 different IP cameras, each showing a different area of the playing surface
- 1 color input ("A") that combines "Scoreboard 1-5" inputs in a single view
- 1 colour input ("B") that combines "Cameras 1-5" inputs in a single view
- 1 colour input ("C") that combines "Cameras 6-10" inputs in a single view
- 1 colour input ("D") that combines "A", "B", and "C" inputs in a single view
When I create a new colour input ("Everything") and add the "D" input to it via MultiView, nothing appears.
Is there a limit to the number of layers for inputs? In my case, it's a pyramid with the original sources at the bottom:
Everything
D
A | B | C
Scoreboard 1 | Scoreboard 2 | etc. | Camera 1 | Camera 2 | etc.
I need the "Everything" input because I want to combine additional content with "D", and "D" is already using 3 of 5 MultiView slots.
#2 Posted : Wednesday, February 5, 2014 10:31:30 PM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Each input will render up to two layers of multiview.
So input A can display up to 5 multiview overlays each with one level of multiview overlays of their own.
With this setup you can theoretically display 30 inputs at a time.
wscawebcast
#3 Posted : Wednesday, February 5, 2014 10:57:10 PM(UTC)
wscawebcast
Thanks for the explanation, Martin. If I'm following you correctly:
Input A
---MultiView 1
------MultiView a
------MultiView b
------MultiView c
------MultiView d
------MultiView e
---MultiView 2
---MultiView 3
---MultiView 4
---MultiView 5
So:
- Input A has a Main and 5 overlays (MultiView 1-5)
- Input 1-5 have a Main and 5 overlays (MultiView a-e)
But MultView a-e cannot have any overlays, and must be single inputs (Main only). Is that correct?
