aircooled76@gmail.com
#1 Posted : Tuesday, April 9, 2019 9:56:24 PM(UTC)
Rank:: Advanced Member
Hi Guys,
I do a fair bit of sport (Ultimate Frisbee) I am looking for a way to send a command to vMix to select the last two clips, or last 3 clips. At the moment we have a shortcut to play the last clip, but sometimes it would be great to play the last two.
Any suggestions? We are currently sending commands via the Web API.
cheers
Mike
Radiotvpat1982
#2 Posted : Friday, April 12, 2019 1:18:14 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
I am not sure how to do this with a web app but on my machine I just highlight the clips I want to play (remove or add check marks to add or subtract cams) then hit the option to: Play Selected Clips
Maybe you need something different but this should work for what you want
#3 Posted : Friday, April 12, 2019 9:44:21 AM(UTC)
I need to do it remotely from the machine. Ultimate Frisbee has very low budgets so we don't get an director / operator most of the time :(
#4 Posted : Friday, May 15, 2020 6:49:26 PM(UTC)
If we can add this feature I will do a video Kareoke song of Martin's choice!
#5 Posted : Friday, May 15, 2020 7:00:28 PM(UTC)
there is replayselectlastevent and also replayselectpreviousevent, and next
so with a bit of combining i believe it should be possible to do what you want , maybe even adding some triggers
#6 Posted : Saturday, May 16, 2020 8:18:32 PM(UTC)
Thanks for the suggestion, I think that only selects one clip at a time (the last one or the previosu one) so still not getting the last two.
I posted a feature request for this that I think is fairly straight forward to implement.
