lremedia
#1 Posted : Sunday, March 31, 2019 1:38:26 AM(UTC)
lremedia
Netherlands Antilles
Hi there I am confronting a issue here, I am using my laptop (Asus) at a point when I'am using vmix on battery my Render Time flies from 5ms up to 200ms and my images are not smooth anymore. Images starts to jugging and soon as I plugged in my power adapter it slows back to 5ms. Any suggestion what will cause this to happen? that affect my whole performance, I normally work on power adapter but I had a gig where I had to use battery on my PC.
Any suggestion or solution?
MartLeib
#2 Posted : Sunday, March 31, 2019 1:43:53 AM(UTC)
MartLeib
Estonia
Make sure you disable all power saving features and force use of the dedicated video card.
lremedia
#3 Posted : Tuesday, April 2, 2019 12:19:19 AM(UTC)
lremedia
Thanks MartLeib,
I did all that I can but still the same, is there any link that can help? maybe I am not doing it right.
Any suggestions I would really appreciate it
Thx
