Systems
NVIDIA P5000 VS RTX 2080TI
Joined: 3/7/2019(UTC) Posts: 9  Location: Medellin Thanks: 1 times
Hello!
I will have four (8 in the future) 4K cameras at 60FPS and i like to know which graphic card is better for my desktop build: NVIDIA QUADRO P5000 OR NVIDIA RTX 2080 TI
So, the specs of the future PC build are: HP Z4 G4 Workstation i9 7940X 32GB RAM P5000 16GB (maybe). (Outputs may be used for: Software display, Multiview, Program). 2X Blackmagic Design DeckLink 8K Pro (Inputs - Maybe One output for screen) 1X Blackmagic Design DeckLink Quad 2 (Rarely use inputs like pc, dvd, etc - Output for AUX). Samsung 960 EVO NVMe M.2 1TB SSD Samsung 860 EVO Series 2.5" 2TB Seagate BarraCuda 8TB
Around: $4682 without SSD disks.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Quadro card is the way to go, I personally would get the RTX series Quadro RTX 4000 or the Quadro RTX 5000 instead of the Pascal series.. the RTX 2080TI only has 2 Max # of concurrent sessions as the RTX 4000 or RTX 5000 have unlimited Advantage going to RTX series vs P Series HEVC B Frame supportDisadvantage going to the RTX series vs P Series only 1 NVENC hardware encoderQuadro RTX 4000Quadro RTX 5000See chart Video Encode Decode GPU Support MatrixOriginally Posted by: manuelgomezo  Hello!
Systems
