GT
Changing PNG Seq Loops via Data Source
Was thanked: 8 time(s) in 2 post(s)
Hey all!
I've been experimenting a bit with the new GT and decided to try to change the png seq being played on loop in a graphic and have it fade in and out on a data change, I find I can change to a new seq via data once (while the graphic is live) with no issues but then when I try to change it a second time it just stays stuck on the Seq its currently playing, becoming desync'd with the rest of the data. Only after taking it off the program out does it load the selected png seq.
I was wondering if anyone has found a solution for something like this using GT or other software as I'm using PNG seqs to preserve an alpha channel and being able to control it via a data source sheet was super easy.
GT
