michaelrb
#1 Posted : Saturday, March 9, 2019 8:11:10 AM(UTC)
michaelrb
The best audio quality on phone calls I have been able to attain is with a Bluedriver M3 device. It pares with my iphone. I recently switched to all digital using my computer. I would like to incorporate the device into vmix. The phone sends audio to the device on my mixing board.(Mackie Fx12) My mic is also attached to the mixing board. I use the mixers usb codec to get this mic into vmix. To create a mix minus 1, I send my voice to a monitor mix, and set the devices monitor mix to zero. The monitor mix from the mixer is then sent back to the device via a physical cable that is attached to the blue tooth device input. [https://forums.vmix.com/resource.ashx?i=3109&b=1attach]3106[/attach] device input and power supply.jpg (409kb) downloaded 0 time(s). mIc and device input.JPG (1,275kb) downloaded 1 time(s). mon mix output to bluetooth device.JPG (1,908kb) downloaded 4 time(s).
Sorry about pictures being how they are. Not sure how to position them on this post.
thanks 1 user thanked michaelrb for this useful post.
sickley1 on 3/11/2019(UTC)
