Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
Hi Martin, good day and good job as always.
Regarding the snap shot button that is used to take photos from the program out, update it to include features such as:
1. To select the location for snap shots to be saved on the computer or external device if needed. 2. To select what image format we want to save the picture as (jpeg, png,bmp, tiff, etc) I think the default format is png. 3. And can you add an option to see each file with a preview or to select between list, tiles, and icon in the input section for previewing of photos, images, videos, and maybe audio in there respective menus. 4. Also for Power Point, Title, and DVD with an option to show full file path or just the name of each file. 5. And an option to remove a particular file added to the input under videos, photos, images, etc. instead of pressing clear and everything clear. 7. Putting some request together for vMix Title Designer.
Thanks much
