Longur
#1 Posted : Tuesday, March 5, 2019 3:00:58 AM(UTC)
Longur
I have a script that updates a text file that vmix uses as a datasource. Quite often when the text file is updated, the text is changed after the animations. Here is an example, if you look at the scoreboard at 1m14s. The text file is updated from player names to twitter handles which triggers the data change animations but the text changes after the animations not between.
EDIT: I changed my script to update the text on the title directly rather than updating a datasource and linking it to the text. That change seems to have resolved this issue
