Joined: 5/12/2016(UTC) Posts: 5 Location: Lyon, France
Hello, I am trying datasources for titles and i don't know how to use the "active" tab (table) for titling. I explain: - I have a google spreadsheet with some differents sheets for my shows as Show1, Show2, Show3 etc... Each sheet as the same structure, same columns. - The sheet is linked and usable in the vMix "Datasource Manager". No problem here. I see my differents sheets in the "Table" list. - In vMix i have a title and here is the problem... I would like to use the current "selected" "table" of the "Data Sources Manager" for my title. Actually it is not possible as the "Title Editor" data source mapping don't allow to use "current selected" table. You have to select one table in the list. Illustration: https://imgur.com/a/42hUCeo
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
As you indicate it to be different shows anyway the simplest thing to do is set your titles for "sheet1" and then move the sheets prior to a specific show in your excel file and all would be correct for that specific show . would beat changing the title settings to indicate a different sheet(show)
