Systems
Intel CPU 8700 or 8700k?
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Looking at putting together an 8 cam 1080 based system (quad duo) with a GTX1070. Is it worth getting the i7 8700K over the 8700? The benchmark differences don't look anything near worth the 25% price hike.
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
The K series allows you to overclock if needed. That seems to be the only difference.
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
I use the Video Replay and the recording on Vmix with my i7 8700K, a 1060 on my laptops + 3 Magewell usb Cauptures + NDi and i have no Problems The CPU is Maximum on 50-60% and the GPU maximum 20-30% if the configuration correct on the GPU Treiber ;)
Systems
