Need help for TS file with CBR
Morning, It is not really a question about Vmix, but I have some problem to find solution. I need to stream with VMIX a TS file with a constant byte rate. I transpose .mov to mp4 with Hanbrake, and I package TS with Avidemux. But Hanbrake don't generate constant byte rate, only average byte rate , do you know an other software for make CBR ? (not ffmpeg, a gui software) Regards
