Longur
#1 Posted : Sunday, February 24, 2019 6:16:19 AM(UTC)
Longur
When I try to add any GT title, there is nothing but a black screen. My old XAML titles still work.
Video: https://drive.google.com...zD0dZiHeVCwHbPM9h0ByA3pd
System:
Processor: Ryzen 1920x Threadripper
Motherboard: ROG STRIX X399-E GAMING
Memory: Corsair Vengeance LPX 32GB 3200 RAM
Video cards: GTX 1060 & GTX 1050
Capture cards: Blackmagic duo 2 & Magewell Quad SDI
ask
#2 Posted : Sunday, February 24, 2019 6:42:12 AM(UTC)
ask
Just a guess...but try disabling one of the graphics cards or removing it. In the nVidia controls assign vmix to one of the cards only. Using two Graphics cards is not recommended with vMix.
#3 Posted : Sunday, February 24, 2019 6:47:30 AM(UTC)
@ Longur
Can you clarify the nature of having two GPUs in the system?
vMix performance is actually reduced by 50% on systems using 2 GPUs.
(perhaps related to your issue IDK)
Longur
#4 Posted : Sunday, February 24, 2019 7:35:52 AM(UTC)
Longur
@ IceStream
I had originally just had the 1060 in my system and my system was kinda chugging while using vMix. I had an extra graphic card 1050 that wasn't being used so I made it my primary graphics card (for other applications) while assigning vMix to use my 1060. Luckily I'm currently in the process of getting a 1080ti so hopefully the issue resolves itself.
Guest (5)
