Sony SNC-ZP550 camera not supported for stream input?
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I tried to connect the Sony SNC-ZP550 via the stream input (rtsp support and H.264 codec activated) but it doesn't work: The server is reporting that no streams are currently available on this address.
I entered the correct path: rtsp://192.168.1.xxx/_adx/media/video1
You have been a member since:: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
RTSP/1.0 500 Internal Server Error CSeq: 1 Content-length: 0
That error means the URL is not correct, you will need to confirm with the Sony documentation on what it might be.
Martin vMix
It works with rtsp://192.168.1.xxx/media/video1 (the delay is app. 1second, so rtsp is not noticeable faster then http)
The only problem is that I have to set the camera to unauthorized viewer. rtsp://user:password@192.168.1.xxx/media/video1 doesn't work: 401 unauthorized
Is login not supported?
