michaelrb
#1 Posted : Wednesday, February 20, 2019 7:13:40 AM(UTC)
michaelrb
I'm tired of cables. Which type of headphone integrates better with VMix, USB or Blue Tooth. What are the potential problems with either type. Will be using this device as a headphone, not a headset.
Any advice?
desmar
#2 Posted : Wednesday, February 20, 2019 10:21:26 AM(UTC)
desmar
Canada
I have used off the shelf Bluetooth headset with no issues, but I would recommend having a wired set as a backup in case of disconnects. My Motherboard came with a Bluetooth 4.0/Wifi card. Was good for up to 30ft..
Any advice?
mavik
#3 Posted : Wednesday, February 20, 2019 5:03:12 PM(UTC)
mavik
BT has it's range limitations and the risk of disconnects is relatively high if you roam. There are RF IEMs (InEarMonitoring) devices availabe at arround 100-200$.
USB is wired. So no option. Take a look at B&H or Thomann and search for IEM. You get your results.
elvis55
#4 Posted : Wednesday, February 20, 2019 5:55:32 PM(UTC)
elvis55
Switzerland
richardgatarski
#5 Posted : Wednesday, February 20, 2019 6:40:03 PM(UTC)
richardgatarski
We've found that in some laptops Bluetooth interferes with WiFi on the laptop (i.e. reduces WiFi speed).
niemi on 2/20/2019(UTC)
