Hello, I use nginx rtmp to bring in a live feed from OBS over the LAN. Sometimes, when I'm loading my vmix config, the vmix program will close on it's own for no reason. The message in the event viewer in windows shows flash.ocx unloaded with the following information in the dump:
<?xml version="1.0" encoding="UTF-16"?> <WERReportMetadata> <OSVersionInformation> <WindowsNTVersion>10.0</WindowsNTVersion> <Build>17763</Build> <Product>(0x30): Windows 10 Pro</Product> <Edition>Professional</Edition> <BuildString>17763.253.amd64fre.rs5_release.180914-1434</BuildString> <Revision>253</Revision> <Flavor>Multiprocessor Free</Flavor> <Architecture>X64</Architecture> <LCID>1033</LCID> </OSVersionInformation> <ProblemSignatures> <EventType>BEX64</EventType> <Parameter0>vMix64.exe</Parameter0> <Parameter1>22.0.0.48</Parameter1> <Parameter2>5c65437b</Parameter2> <Parameter3>Flash.ocx_unloaded</Parameter3> <Parameter4>32.0.0.114</Parameter4> <Parameter5>5c181dd6</Parameter5> <Parameter6>0000000000450b12</Parameter6> <Parameter7>c0000005</Parameter7> <Parameter8>0000000000000008</Parameter8> </ProblemSignatures> <DynamicSignatures> <Parameter1>10.0.17763.2.0.0.256.48</Parameter1> <Parameter2>1033</Parameter2> <Parameter22>f9d8</Parameter22> <Parameter23>f9d82b147b6ad3097a0d9c822ca02a2a</Parameter23> <Parameter24>a5b6</Parameter24> <Parameter25>a5b671c4745024b43c9851d184396453</Parameter25> </DynamicSignatures> <SystemInformation> <MID>5DE1D24C-849F-4AA5-A359-56F7980EBD25</MID> <SystemManufacturer>To Be Filled By O.E.M.</SystemManufacturer> <SystemProductName>To Be Filled By O.E.M.</SystemProductName> <BIOSVersion>P5.40</BIOSVersion> <OSInstallDate>1548792191</OSInstallDate> <OSInstallTime>2019-01-29T20:03:11Z</OSInstallTime> <TimeZoneBias>06:00</TimeZoneBias> </SystemInformation> <SecureBootState> <UEFISecureBootEnabled>0</UEFISecureBootEnabled> </SecureBootState> <ReportInformation> <Guid>d014ce34-6df7-444c-a107-363cc2bd712d</Guid> <CreationTime>2019-02-17T03:51:57Z</CreationTime> </ReportInformation> </WERReportMetadata>
I did send a support report. Hopefully you guys or someone can tell me why.
Thanks, Josh
P.S. Using VMix 4k 22.0.0.48 on Windows 10 Pro x64.
