Paul_WCP
#1 Posted : Saturday, February 9, 2019 12:31:18 AM(UTC)
Paul_WCP
Germany
I was wondering if it would be possible to have another mixing layer assigned to an external display.
For example I have a Podium Discussion that I want to livestream that has live transmission with 4 people over vMix Call.
I would want a submix of the 4 Callers in split and cut to the Caller speaking and send that mix directly through external out to an LED Wall.
Then, I would want the mainmix for my stream were I can cut from my Cameras to the Submix.
I know I could just setup a Split as Input and then switch the inputs that are sent to external. But then again the person mixing the stream would have to switch to the correct input and could not just straight away cut to the submix, that could be handled by another person.
Sorry if my explanation is confusing. A different take: on an ATEM you can choose M/E2 PGM as an input and have M/E2 mixed by another Person. I would like to achieve a similar workflow with vMix.
Is this already possible and I just missed it?
richardgatarski
#2 Posted : Saturday, February 9, 2019 1:43:04 AM(UTC)
richardgatarski
Hi Paul_WCP and welcome to the Forum.
If you search for the phrase "mix effect" you'll find both that it is a popular request as well as some possible workarounds. Most recent is in Add M/E https://forums.vmix.com/...aspx?g=posts&t=14556
stigaard
#3 Posted : Saturday, February 9, 2019 9:44:18 AM(UTC)
stigaard
Denmark
Just use two instances (read machines) of vMix.
