Streaming different profiles to multiple locations
Hi! I know that vMix can stream simultaneously to multiple locations and/or stream in multiple resolutions, but! is there a chance to stream different videos to multiple locations? Let's say I have a green screen and I stream one background to one destination and the same green screen with other background to another location? Let's say if i want to stream to Facebook I have the green screen studio with FB logo and then I am streaming the very same studio to Youtube with Youtube logo on green screen.
Any ideas?
UPD.: I've found a solution in the forum and will post it here for other users struggling:
In order to stream different sources to different destinations you need to have a PRO version of vmix or at least 60 days trial and:
FIRST - Activate "multiple instances" feature: 1) Goto settings. 2) Select Options 3) Select show advanced setting. 4) Select Check Box for Enable Multiple Instances 5) Select OK 6) Select Restart vMix to apply changes..
Then you can run multiple instances of vMix...
If one of the streams crashes (most probably due to media live encoder), do this:
Copy vmix folder (vmix copy1, vmix copy2 etc) in program files That creates a duplicate of vmix and ffmpeg. Every duplicate folder has its own settings so you must check before running multiple instances in every vmix copy checkbox enable multiple instances.
Ta-da!
