PaulV8
#1 Posted : Sunday, February 3, 2019 12:29:51 PM(UTC)
PaulV8
I am fairly new to vMix and just heard about Restream. This is perfect for streaming to multiple destinations. I set it all up on my computer at home and it worked quite well.
When I went to our main computer, I could not log into restream from the vMix stream setup. I thought it was a Restream server issue. I went online to chat with them and they said all was working on their end and the problem must be with vMix. I was able to start a browser and log into their main website, but could not log in using vMix. BTW, I could also start the streams manually (not in Restream). Is there something I am missing? Maybe some setting somewhere.
kjones9999
#2 Posted : Monday, February 4, 2019 1:07:21 AM(UTC)
kjones9999
I would just try to do a custom rtmp with their address and your key. I have used it this way for years, and it takes out all the guesswork.
#3 Posted : Monday, February 4, 2019 1:16:20 AM(UTC)
What error message do you receive?
I can confirm logging in to Restream is working correctly here,
however it is possible it may not work on out of date versions of Windows due to new security policies on most servers.
If you do not have Windows 10, check to make sure all windows updates are installed.
PaulV8
#4 Posted : Monday, February 4, 2019 1:57:50 AM(UTC)
PaulV8
I get a blank white screen that says "Navigation to website has been cancelled"
I am using Windows 7-64 and all the Windows updates are up to date. This is strange because I have a similar system (Win7-64) and this one works just fine.
PaulV8
#5 Posted : Tuesday, February 5, 2019 7:43:56 AM(UTC)
PaulV8
I was able to use Restream by inputting the URL and stream name maually using the custom RTMP setting. Still confusing why the API does not work in vMix.
Guest (5)
