Jim_C
#1 Posted : Sunday, February 3, 2019 4:43:33 AM(UTC)
Jim_C
If we have a venue blanketed in our on wifi/lan network, but no internet access, is the Newtek or Sienna app the only choice to broadcast from an ios or Android device?
The wonderful vMix call interface only works thru the internet correct?
Thanks for any help or suggestions.
Jim_C
#2 Posted : Sunday, February 3, 2019 4:45:44 AM(UTC)
Jim_C
and a second question, between the two, which app have you found to work better. I have the Newtek one and its a little shy on options and also broadcasts in 4:3 ... which seems odd.
mjgraves
#3 Posted : Sunday, February 3, 2019 5:42:15 AM(UTC)
mjgraves
NDI Camera app for Android works well enough, if your Wi-Fi is really solid.
Otherwise, RTSP camera server (https://play.google.com/store/apps/details?id=com.miv.rtspcamera) app can be used. Since it uses H264 there's some latency, but bandwidth requirements are much less than NDI.
It has a built-in RTSP server, so you add it as a stream source, like a surveillance camera. No internet access required as long as you have IP addresses or internal DNS solution.
Jim_C on 2/3/2019(UTC)
Jim_C
#4 Posted : Sunday, February 3, 2019 6:11:03 AM(UTC)
Jim_C
Thanks MJ,
Good info.
elvis55
#5 Posted : Sunday, February 3, 2019 7:21:09 AM(UTC)
elvis55
Switzerland
Hallo,
Install on the PC.
RTMP MiniServer
Android App.
Larix Broadcaster
thanks 1 user thanked elvis55 for this useful post.
Jim_C on 2/4/2019(UTC)
Jim_C
#6 Posted : Monday, February 4, 2019 2:34:50 AM(UTC)
Jim_C
Thanks elvis
