How to use audio from one DV camera all the time while switching between cameras?
Hi!
I think vMix is really great, but I'm wondering about one thing: I have two DV cameras and I switch between them, and at the same time the audio is switched so that the audio comes from the camera which is active. But I would like to lock the audio to one of the cameras, how can this be done? I'm sure it's possible, I just can't find it anywhere.
I also need to play AVI files now and then, and when the AVI plays I would like the sound to come from the AVI and not from the camera. Is this possible? But more important would be to be able to lock it to one of the cameras.
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
click on advanced in the top right> then click on the speaker icon in the bottom right uncheck the follow audio icon, (orange and green arrow) like in the screen capture down the post, for the audio input that you want active all the time. Also make sure that the green speaker is checked on this source. Second uncheck the same button (the follow green and orange button) for the audio source you dont want to use. If you want to play audio with a video the audio should automatically start when the input turns live. But remember cause you have deselect the follow audio on the camera to manally turn the audio on the camera down by moving the slider down or depressing the speaker icon (or audio icon under the source).
