attilio18
#1 Posted : Thursday, January 24, 2019 10:03:53 PM(UTC)
attilio18
Hi, in vmix 21 using the ticker in the scroll you see slight shots .. The scrolling of the text is not uniform.
I still can not use the vmix 22 version being beta some functions in vmix that I could not use ..
If someone has the same problem how did he solve it?
the configuration of my pc is as follows:
cpu: intel core i7-7740x - 4.30 GHz
Nvidia Geforce GTX 1060 6GB
Blackmagic decklink quad2
Motherboard: Gigabyte Z370 AORUS
Thanks for the attention.
Attilio
#2 Posted : Friday, January 25, 2019 8:49:30 PM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Tickers in vMix 21 and earlier have a fixed duration that is set by clicking the clock icon in the Title Editor window.
As a result of a fixed duration, it may not be possible to move ticker text at the exact same difference every frame.
To resolve this you will need to adjust the duration until the ticker is smoother.
Tickers in vMix 22 move at a fixed pixel rate by contrast, so this problem should not occur there, but
it is not possible to add this behaviour to the old tickers, so the above is the only workaround.
attilio18
#3 Posted : Friday, January 25, 2019 11:21:08 PM(UTC)
attilio18
Hi Martin, I tried to set the time but I do not get results. I thought it depended on the graphics card. when will vmix 22 be released?
I downloaded the beta version, but many features are blocked.
I use vmix every day for work and for this I am still forced to use vmix 21.
thanks for the quick response.
See you soon
#4 Posted : Saturday, January 26, 2019 12:33:39 AM(UTC)
vMix 22 will be released at NAB, in April 2019.
As you have vMix 4K you will have access to all features, including tickers.
Can you describe in more detail what features you are seeing as blocked?
attilio18
#5 Posted : Monday, January 28, 2019 9:04:03 PM(UTC)
attilio18
Hi, with the newly released Beta 22 version, I had problems with vmix social and NDI. now I downloaded version 22.0.0.42 and everything seems to work.
It is not clear to me, with my license vmix 4k purchased December 2018, I will have to pay the 22 when it will be released?
