Joined: 12/1/2018(UTC) Posts: 26  Location: Florida Was thanked: 1 time(s) in 1 post(s)
In vMix 4k and above with two displays for fullscreen, it would be helpful if there were two fullscreen buttons instead of one at the top of the screen. As it is now, if fullscreen is on, then both displays are on, and if fullscreen is off, both are off. Two buttons would allow control of the two diaplays independent of each other. Also, it would be helpful if we could rename each of the fullscreen buttons similar to the way you can rename each input.
 1 user thanked PaulV8 for this useful post.
Joined: 1/26/2019(UTC) Posts: 6  Location: Jeddah Was thanked: 1 time(s) in 1 post(s)
Joined: 8/25/2018(UTC) Posts: 23   Location: Da OC, CA Was thanked: 1 time(s) in 1 post(s)
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
