imagebotique
#1 Posted : Wednesday, January 9, 2019 11:51:01 PM(UTC)
imagebotique
After sending a email in exactly 11 months ago this morning I received a reply from Elgato stating that there was a SDK available. I am hoping and assuming that this may be what was missing in order for Martin to get this piece of hardware to work properly with vMix. This is the email they sent. Hopefully this can be either added as a update to vMix21 or included in the beta of 22 soon.
JAN 09, 2019 | 03:59AM PST
Alexandre Colucci replied:
We just released the Stream Deck SDK which let you create custom actions in Stream Deck.
You can find the documentation online and some sample plugins here:
https://developer.elgato...cumentation/stream-deck/
Best Regards
#2 Posted : Wednesday, January 9, 2019 11:57:19 PM(UTC)
Seems Martin is way ahead of you
here
vMix 22 has full support for the Elgato Gaming Stream Deck! You'll be able to assign your (over 300) vMix shortcuts to Stream Deck keys. You'll just need to grab the vMix app from Stream Deck 4.0 and then assign shortcuts to the keys. Then head to vMix to add your shortcuts. Here's a quick guide, but we'll making a video tuturial closer to the official vMix 22 release.
imagebotique on 1/10/2019(UTC)
grinsekatz01
#3 Posted : Thursday, January 10, 2019 11:02:15 PM(UTC)
grinsekatz01
Austria
Works great for me - because of the recognized 2 positions(Button up/down) of each key, PTZ-control is now possible with Stream Deck.
Greets
edit:
Choosing the "Thumbnail"-setting crashes the plugin..and the Stream Deck stops working - even after re-starting the PC.
After deleting all shortcuts and new setup, works fine again..
grinsekatz01
#4 Posted : Friday, January 11, 2019 7:36:31 PM(UTC)
grinsekatz01
Austria
after some success, the plugin now finally stopped working.
Stream Deck is no longer seen by vMix 22.0.0.38.
Greets
