Joined: 1/8/2019(UTC) Posts: 15  Location: dallas tx Thanks: 1 times
I am a new user and cannot get the video only to play to a monitor. I have a camera coming into V-Mix through a capture device to my laptop and I am using the HDMI port on my laptop to the monitor. I can only get the V-Mix control page on the monitor. I have viewed all the tutorials on the subject and pressed the fullscreen button but nothing has worked. I just need the video on the right side on my control page to be output. Can someone help me?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
If you go to Settings (top right) and you choose "Outputs/NDI" next to "Fullscreen", the Source should be "Output"
If this is ok, your laptop is probably on "Duplicate". Hit "Windows/P" and choose "Extend"
Also, the computer's Multiple Display settings should be set to "Extend these displays" (for Windows 10), and not "Duplicate these displays", in order to see something different on the second screen, or else you will probably just see the vMix GUI on both.
Thank you for your response. My settings were all set to output.  Screenshot 2019-01-07 12.50.15.png (176kb) downloaded 1 time(s).Is there something else I can do?
See my second point; hit Windows/P and choose Extend instead of Duplicate
Here is the correct screenshot  Screenshot 2019-01-07 12.56.32.png (100kb) downloaded 0 time(s).
Oh my goodness...you are so good and I thank you soooo much. That corrected it as you thought. I appreciate your help.
