guztavo
#1 Posted : Wednesday, December 19, 2018 7:28:08 AM(UTC)
guztavo
Hi!
I'm writing because i want to know how do you do to make your Windows installation stronger.
A few days ago my backup PC just stop working (never finish'd booting) so i had to make a new clean installation.
Do you use more than one HDD? RAID setup? Disk freeze? Disk image?
For now, two PCs works for me but i know farily is not an option (when i have 2 streamings on same day im lost if one fails).
Thanks in advance.
Joeboe
#2 Posted : Wednesday, December 19, 2018 7:58:21 AM(UTC)
Joeboe
Do what I am doing...Clone your HDs, and keep them in the PC case...I the event of a freeze, crash, and you can not reboot, just open the case, connect the cloned drive, and off you go again until you can get a fix.....saved my butt a few days ago, when I was testing for an appointment.....just had to disconnect the main drive, connect the clone , and all was well again....
mjgraves
#3 Posted : Wednesday, December 19, 2018 8:55:54 AM(UTC)
mjgraves
RAID can be complicated, but also a lifesaver. I used a system with a RAID1 boot volume for many years.
These days my systems boot from SSD. It's possible to have a cloned image on a backup SSD ready to go. There are event mounts that provide accessible, hot-swappable SATA SSD slots.
guztavo
#4 Posted : Saturday, January 5, 2019 1:47:41 PM(UTC)
guztavo
Thanks for answering!
Wich app do you use to clone por freeze the c: unit?
Thanks!
