I did a quick search on the forum, nothing about audio for this. I'm looking at getting the IO4K plus, and wasn't sure if the analog XLR had ASIO support, would I be able to import each channel independently? If I do that, am I able to use the embedded SDI audio on each camera as well or am I limited to either analog or embedded?
