vMix Midi Mapper v0.1.0 - VMIX 12 Update
Hi all,
Is this version still working for vMix14 ? And when i try to install v0.1.0 i get following error
[img][/img]
"File VmixMidiMapper_beta_v0_1_0.CAB is not found..."
And indeed, that file isn't in the .zip-file
Greetings,
bmwkid
Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
Hi, I really like your app, but I'd really like if you or someone can add an option for "setFader". And an ability to record from one "Live MIDI data" to another. So let's say that your app automatically sets a value by dividing an amount from first step to last step. Let's say: http://127.0.0.1:8088/api/?function=SetFader&Value=00 ---- 000230E0 http://127.0.0.1:8088/api/?function=SetFader&Value=10 ---- 001130E0 http://127.0.0.1:8088/api/?function=SetFader&Value=20 ---- 001B20E0 http://127.0.0.1:8088/api/?function=SetFader&Value=30 ---- 002370E0 http://127.0.0.1:8088/api/?function=SetFader&Value=40 ---- 002950E0 http://127.0.0.1:8088/api/?function=SetFader&Value=50 ---- 002F20E0 http://127.0.0.1:8088/api/?function=SetFader&Value=60 ---- 003470E0 http://127.0.0.1:8088/api/?function=SetFader&Value=70 ---- 003900E0 http://127.0.0.1:8088/api/?function=SetFader&Value=80 ---- 004970E0 http://127.0.0.1:8088/api/?function=SetFader&Value=90 ---- 005040E0 http://127.0.0.1:8088/api/?function=SetFader&Value=100 ---- 005D10E0 and so on... Is that possible to create? Thank you!
Rank:: Newbie
if someone could send or write me a link to download the current program vmix midi mapper ?. I would like to test the program with akai apc 40. :)
Hi everyone, Is the vMix Midi Mapper still being developed? Does anyone have install files or does anyone know legit download link?
Thanks in advance
This is obsolete because vMix 16 will have native MIDI support. Just wait a few days for the download.
