javier.acosta
#1 Posted : Thursday, December 13, 2018 9:15:19 PM(UTC)
javier.acosta
Spain
Hello!
We've been working with vMix for some time now and I have a suggestion that our working system would be very good.
We would need to send three streams to three different URLs from three different outputs. That is, send master and two auxiliaries independently to a server.
I hope this improvement will come soon, because it would be very interesting for us!
Thank you very much!
StepBackInTime_TV
#2 Posted : Friday, December 14, 2018 1:57:31 AM(UTC)
StepBackInTime_TV
Rank:: Advanced Member
Was thanked: 17 time(s) in 14 post(s)
Hi ... We showed a way that you can do this on WOLS a few weeks back - it would be cool to be able to do it direct from within vMix itself, but this simple (and free!) solution may work for you:
https://youtu.be/kx_Y7M1-crE?t=2578
My little presentation was based on using multi-camera you-tube, but I think it could be equally applied to your use case.
Hope this helps.
Giles.
javier.acosta
#3 Posted : Friday, December 14, 2018 2:54:01 AM(UTC)
javier.acosta
Spain
HI Giles!
I have been watching your video and I think that it is exactly what I am looking for. I have a question about qualities, can I broadcast on 4k from your program?
Thanks a lot!
Javier
StepBackInTime_TV
#4 Posted : Sunday, December 16, 2018 12:58:23 AM(UTC)
StepBackInTime_TV
Originally Posted by: javier.acosta Go to Quoted Post
HI Giles!
Javier
Hi
I think it should do 4K - its FFMpeg behind the scenes - much the same as vMix, so as long as you have the hardware (GPU) to cope with it, I don't see why it shouldn't work at 4K - but I am unable to test this.
