TracyPeterson
#1 Posted : Thursday, December 13, 2018 2:04:20 PM(UTC)
TracyPeterson
Hey all,
Thanks for being such a helpful community. My computer has an issue where it doesn't update the preview window in the configuration window. I can see when I make adjustments like cropping or color correction, but it doesn't update in the window, I can only see the original camera input, raw. I can see the changes in the live preview, or program, but not in the settings preview. Any chance this is some check box I can't find? I have tried numerous settings changes but I can't find whats causing this behavior.
Tracy
#2 Posted : Thursday, December 13, 2018 6:40:01 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Check settings -> Performance and tick Show Advanced Settings.
Then untick "Disable effects on Input Previews" as this should be off normally.
